I think calculix 2.16 (at least the version for win32bit that I use with mecway9) omits to calculate or miscalculates the lowest buckling modes when acr<1 (I am aware of the shift point concept). Mecway solver in general ,or calculix 2.15 have no problem. Anyone else noticed this?
Otherwise, can you upload an example with the solution showing what the error looks like?
Here is a summary of the problem:
The number of procesors in my computer's system variables is 1.
When the buckling factor (acr) is greater or equal to 1 there is no problem with calculix 2.16.
When the acr is<1 the calculix 2.16 gives wrong results, while other versions e.g. 2.15 and lower have no problem.
I use mecway9,32bit, and ccx,32bit versions. Please see attached images and liml file.
In the particular example when I use calculix 2.15 or mecway solver the acr~0.16, but calculix2.16 shows acr~0.86 and from the buckling shape it is obvious that omitts lower buckling modes.
There are two "versions" of CCX 2.16. An older one and a newer one. The differences are:
Older version:
Newer version:
