I have been using MECWAY to extract the shear and moment diagrams for beams by using the post processing feature which does this. However I noticed that when compared to analytical results found in typical textbooks, the shear is in opposite sign of typical convention. I think this may be because typical positive internal shear definitions require that it causes the element to experience a clockwise rotation while the positive/negative conventions for moment are aligned with typical clockwise/anti-clockwise convention for positive and negative angle.
Is this a bug or just a different sign convention being used?
Thanks.
