Nodal supports 6 DOF
Hi All
When constraining/ supporting nodes is there a way to constrain particular degrees of freedom rather than using the standard fixed of frictionless supports. I'm looking for a way of constraining any number of degrees of freedom for nodes from TX TY TZ RX RY RZ.
Kind regards
  • The Displacement and Node rotation constraints do that. Each one constrains a single DOF. Choose one of the predefined orientations (X, Y, Z) to populate the top row of input fields and they will behave like traditional global DOF constraints.
  • Is possible to add a boundary condition widget to be able to pick several/all dof of a node/surface set? I mean, in one window.
  • I also would love the ability to toggle on/off multiple DOF constraints in a single window.
    Thanks, Pete.
  • Thanks for suggesting that again. I'm not sure about it at the moment but it's on my list to sort out.
