Hello everyone
I was trying to make displacement-based load to my structure to simulate push-over analysis (this method is popular in civil engineering to simulate earthquake).
This way, several nodes above top of structure are "pulled" with incremental displacement.
I created displacement-control load, it shown the correct graph of displacement to max 100mm, since my formula is 10*t, and t max is 10 seconds.
But when I checked the displacement in results of analysis, these top nodes is pulled to 1000 mm within 0.1 second and then stopped there.
Can anybody check, if I miss something to my model?
Thank you
Even if I changed the geometric from L-shape to Rectangular-shape to remove the red entries, the results still in similar manner.
Strangely, when the analysis was performed by Calculix (using general-shape), the displacement shown the expected displacement of 100mm.
It looks like you may have to use a force instead. This could be a large force on a stiff (relative to the tower) external spring so that it behaves approximately like a prescribed displacement.
Hello Victor,
I thought the displacement can be non-zero, since there is guidance to insert formula below the input field. I think it's common to use non-zero displacement for FEM software. Is it the behavior of the software itself or it's not implemented yet?
Be aware that CCX doesn't have the angle beam sections.
