Hi all im looking for a good guide and some info on the best way to model composite laminates using Mecway. i'm analysing a composite wing for a light aircraft that uses fairly simple layups with unidirectional spar caps and bidirectional +- 45 degree layups for wing ribs and shear webs. im also keen to find out the best way to model cored panels made of nomex honey comb and and carbon face sheets
Cheers
Michael
yeah i know what you mean. i'm in the same boat as well. i used algor way back in the day. nastran then ansys. the licensing fees are nuts. mecway is great. you can do composites. it's just not it's strong suit. compared to a spreadsheet it would be way better. since you have experience with them, i think you have a good chance at success. i don't have that much experience with them and i still managed to get what i wanted. it just takes awhile at first. i would still suggest a small model or two before you try a whole wing. i'm not sure if you have used mecway yet but you might have a bit of learning to do in general and then there is the composite aspect. there are a few ways you can go about it. you can use multiple parts and contact. you can use the laminate feature. lastly, you might be able to do something like what i did and got around having to use the laminate feature. i went back and watched the fea videos i did yesterday. unfortunately, there is lots of things spread out over all the videos. so it's hard to say any particular one. in the advanced composites i forgot some things and had to go back with the following two videos to cover those aspects.
you can define tsai-wu or any failure criteria you want. that is one of the great things about mecway. the built in tsai-wu is only for the mecway solver. unfortunately the mecway shell element is very limited so you probably won't use that at all. if you use the ccx shell or laminate, they turn into solids. you have to define your own criteria with those. with either solver you have to define your own material properties.
Here is a composite mesh of a aircraft structural wing box i have made up. It has unidirectional fibers of varying thickness along the spar caps and BI directional carbon fibre for the skins and ribs. I have run it and it compares well with other analysis i have done and data i have. I would like to see what the effect of using carbon fibre/Honeycomb sandwich panels in the wing skins and ribs would be. I would like to reduce the number ribs too. How can i model sandwich panels in Mecway? . Im mainly interested in capturing the stiffness increase they provide. I have done some spread sheet analysis to work out the basic properties of simple sandwich panels but i am unsure how to put them in to MECWAY. I am not so much interested in accurately modelling failure modes in sandwich panels....there are other ways to work that out i just need a reasonable idea of the stiffness they provide to the wing.
thanks
michael
the core material is .25 in thick honeycomb and only its shear modulus of 5800psi and its shear strength is given in the material spec sheets....The values i entered for E and Poissons ratio for the core material were just guesses to see if it would work. is this the correct way to enter in laminate details?
0.03, 0, 3200000, 3200000, 0.1, 120000, 0, 0
0.25, 90, 100, 100, 0.1, 5800, 5800, 0
