Trying some initial simulations to model heating in a resistive filament. I have tried with solid hex elements, but the resistor option is not available. Tried with line elements (both with and without finite section thickness), I gave them a resistance, I get potential and current solutions, but adding power density to the solution gives a red entry in the tree: Compatible with element types and materials: unknown. What am I missing? Thanks.
Prop design, I know not much about Salome. I have it installed and have had a go, but I found it quite confusing. I believe it does do hex dominant. It looks like a useful tool.
These lovely helical meshes were done in Mecway 11, and were pretty straightforward. I'll try to remember what I did. To create the helix I used >Mesh tools >Create >Curve generator >Cirlce. Enter two equal radii for the overall diameter of the helix, then OK, which will return you to the Curve generator window with the parametric equations to generate a circle. Change the Final p entry from 2*pi to, for example, 20*pi to give 10 turns, then in the Z box enter some small value *p to move the helix along the z axis, such as 0.003*p. Increase the Number of elements figure to give a sufficiently smooth curve. Hit OK and you should have your helix made of line elements (subject to a bit of tweaking of the figures). Next >Mesh tools >Create >Plate mesh and enter the radius of the wire, and -if you like- adjust the meshing parameters (with a live preview, I think). This gives you the cross section of the wire. I moved this cross-section so that its centre was on the end of the helix, then rotated so that it was oriented normal to the end of the helix. Merge the two nodes at the centre with the Merge nodes tool. Next use the sweep tool: for the profile select your cross section, and for the path select the helix (I had these as named selections to make this easier). Hit OK and you should have have your helix. I think you can avoid having to move the cross-section to the helix by linking the helix end node and plate centre node with a line element, but you will have to delete the elements that the line elements create as they sweep.
I think this should work, but if I have misremembered let me know and I will work through it. Pretty impressive built-in meshing tools, I think.
But I'm impressed you've meshed this with Mecway!
I am trying to set up a Joule heating simulation to display maximum radial heat in the center of a small brass wire. I have worked out the math, and know the answer, I want to learn how to simulate it. I have read the manual but still my simulations generate values which do not make sense. I've searched for online examples and tutorials but haven't had success.
Here's what I'm trying to do::
Starting with a small brass rod 1mm dia. x 5mm long, I am applying 0.42A. Ta=ambient 20C , h=10, K=109 Tmax should be approximately 50C
Using temperature dependent material, setting parameters t using DC Circuit, switching to Thermal transient, I've tried thermal steady state too. My results display a radial heating, and the center is the maxT, but the values make no sense. I am obviously setting this simulation wrong. Any advice would be helpful and appreciated. If I can get my simulation to work, I will gladly share it to help other novices like myself. thanks for reading. - Kind Regards, Marty H
¿Could you detail the Brass material properties units you are using?
Youngs Modulus 112 GPa
Thermal Conductivity 109 W/m3
Poisson ratio .311
Thank you for helping me
What about your electrical properties.?
How did you end up in this value of "Tmax should be approximately 50C".
Heat flow: -5.67W
heat flux: -6.71e+6
Resistance 2.74e-2 ohm
Qin 4.83e-3 W
My math values were calculated on a spreadsheet and when inputted example
joule heating problems match answers.
Clean and with their units.
You started the post saying something about h=10 which now seems that has disappeared, You are mixing material properties with results.
Be sure you understand the difference between Electrical Resistivity and Electrical Resistance. They are only the same for Length/Section =1
Please work it out a little and if you do not advance come later.
It solves the nude and insulated wire. It could eventually help to validate your Setup and Procedure. Read the assumption closely.
The problem and its solution are free access. Theory and Solution are described in the well known book :
Fundamentals Of Heat And Mass Transfer Frank P Incropera
6th-Edition. (Be sure both Theory and problem books are 6th edition. If not Example reference number will not match)
PROBLEM 3.42
Both can be downloaded free here. First check if your custom spreadsheet numbers also match the solution.
https://archive.org/details/FundamentalsOfHeatAndMassTransferFrankPIncropera
https://archive.org/details/SolutionManualFundamentalsOfHeatAndMassTransfer6thEdition/page/n7/mode/2up?view=theater
I can help you based on that problem data.
I don't do electrical FEA at all so probably my first part of the analysis to obtain the internal heat generation could be improved or speed up.
Regarding the thermal analysis I had to do it with thermal transient because Radiation is not available in Steady State.
I have used the same iterative process as in the book to find the heat transfer coefficient Wire/Air. Both, naked and insulated solutions have converged to the expected surface temperatures.
Caution with the units and properties (Resistivity/Resistance , Conductivity/Conductance)
Anyone identifying potential issues with this approach or having suggestions to improve it please comment.
Questions:
-The electrical analysis doesn’t give the current value. It shows in red. Don’t know what’s Wrong. ?¿?
I hope it can serve as reference example.
