There are two problems, I am facing:
- Can't Import the attached stl file. Shows no error but doesnt import either
- Even if the stl file get imported, When I try to give a thickness in material properties to the model it happens bi-directional. How can i set a direction to the thickness of the mesh?
There will likely be more error in that region because shells aren't very good at sharp corners, so don't expect good stress results at the crease and be sure to check for mesh convergence. The whole structure looks quite thick for shells and might be better done with solids.
