Hi. Maybe it is funny, but I don't know how to fix only selected degree of freedom. I default option see "full fix" only. How to fix the only rotation at one axis or displacement in one direction ?
Not easy because i understand that i should add fixation in each direction separately. In other word - i have 3 different BC if I add a "symmetry" (1x displ. + 2x rot.). In other tools/softwares I can select node/geometry and define which dof should be fixed/free. It is so faster...
I see. Thanks. Though for symmetry, you can use frictionless support instead which is much easier as long as the element surfaces are all in the symmetry plane.
select either direction X Y or Z
and leave deflection distance as 0 mm
similarly for node rotational DOF
and leave rotation angle as 0 degree
But it is not easy to use
