I am investigating elastic plastic deformation.
The manual Section 14.1 Custom model definition provides a method of defining custom material properties.
The material is S275 steel.
Yield 275 N/mm^2
UTS 410 N/mm^2
E 210000 N/mm^2
23 % elongation to break
Is my interpretation below correct.
*SOLID SECTION,ELSET=Default,MATERIAL=MyMaterial
*MATERIAL,NAME=MyMaterial
*ELASTIC
210e9,0.3
*PLASTIC
275e6,0
410e6,0.23
Any help / advice appreciated.
Thank You
JN
I am quite comfortable with elastic analysis but I have a lot to learn about plastic analysis.
Can you suggest any reading material which may assist with the basics.
Thank you.
Thank you for the pointers. I have it sorted now.
Jim
