Plastic Analysis
I am investigating elastic plastic deformation.
The manual Section 14.1 Custom model definition provides a method of defining custom material properties.
The material is S275 steel.
Yield 275 N/mm^2
UTS 410 N/mm^2
E 210000 N/mm^2
23 % elongation to break
Is my interpretation below correct.
*SOLID SECTION,ELSET=Default,MATERIAL=MyMaterial
*MATERIAL,NAME=MyMaterial
*ELASTIC
210e9,0.3
*PLASTIC
275e6,0
410e6,0.23
Any help / advice appreciated.
Thank You
JN
  • Hamwik, those are engineering stress/strain values, you must transform to true stress/strain to use in CCX (true stress is a little higher than engineering stress). Also, the second point of your PLASTIC card is the ultimate stress/strain, but you must sustract the elastic strain portion from the ultimate strain (very few for steel, but for other can be significant).
  • Thank you for your comments.
    I am quite comfortable with elastic analysis but I have a lot to learn about plastic analysis.
    Can you suggest any reading material which may assist with the basics.
    Thank you.
  • agree, for plastic analysis always use true stress/strain
  • Sergio / Steve
    Thank you for the pointers. I have it sorted now.
    Jim
  • Another trick is to add an extra point at very large strain (100% strain and compute the stress for this point to keep the tangent modulus constant) in order to help to converge in case of having a very small high plastic strain hot spot in your model. Obvioulsy you must take care that strains/stress values over the ultimate values cannot be taken in count.
