I was just curious why the C, T and L sections are grayed out in the menu for geometric material properties? I am using the 3D modal vibration analysis.
You know, I'm not sure. It might simply be a lack of tests. They seem to work if you switch to Static 3D to set them up then back to modal vibration to solve. I'll look into enabling them properly.
