Dear all,
I'm very new to Mecway and I need to be pushed to achieve my "project". I'm a biologist and I'm trying to perform a FEM analysis on a root of a plant. I need to model it after bending stress that poses it curved of 90° respect perpendicularity to ground (the root forms a "L"). I have the diameters of 15 samples (like rings) of root that cover a lenght of 15 cm. These diameters come from two roots that have temporal differences (and also diameter differences) in the treatment and I would like to create a model indicating me which are the most stressed sectors.
I tried to consider the root as a sort of crane frame (following a tutorial), performing a dynamic response 2D and trying to displace the root from vertical to L shape.
But I think it is not the right way.
Contemporary, I tried to draw directly the root in L shape, but even in this case I don't get any good idea and result.
Please, any suggestion is super-welcome.
Thanks a lot in advance!
Gab
It needs to be a non-linear analysis to capture the large rotation through 90 degrees and I think inertia isn't important so I've used Nonlinear Static 3D.
May be I give you more details to get as much suggestion I can: I whish to obtain a model describing the distribution of the longitudinal mechanical forces along the root (something like the image I attached), in order to describe the differences for the two timepoints I have. The only data I have are related to the lenght of the root (15 cm divided in 15 sectors) and diameters of the root (each sector a different diameter....you can find them in the .xls file).
Other info I have are related to wood that is considered to be mechanically isotropic (Young's modulus of 5GPa, Poisson's Coefficient of 0.3) and a density of 1000kg/m3.
Thanks a lot again and I would be happy to receive other inputs.
Gab
In either case, I would start with a 2D mesh of the section from the longitudinal axis to the surface and then revolve that to form the cylinder. Also, start with quadratic elements for smooth curves when you revolve and refine it.
thanks a lot for all suggestions you gave, they were precious while building the model.
Now I have another question about the output of the analysis. Is there a way of getting the mean stress of the longitudinal mechanical forces in a specific section of the model?
Through the "new table" tool can I get values of a selected portion of elements?
Thanks a lot again for availability,
Gab
In version 9, you could make a very thin section and use Solution -> Mean to average the stress over that thin volume.
The table can show values for elements in components or element selections that were defined before solving. They'll be available to select in the list in the top middle of the Table window.
