i wan to appy a radial displacement of shell cylinder to crimp or expand stent in mecway. For this I need a cylindrical coordinate system. One knows how I can do something like that.
The following picture represents what I need. many thanks for your help
*TRANSFORM,NSET=NSET_INNER,TYPE=C
0.,0.,0.,0.,0.,1.
Also, your model is simetric, so you can use just a quarter of your geometry or even a sector and use the *CYCLIC SYMETRY card that will also allow you save the results for the whole model.
I have tried to solve using a ballon with contacts to expand the stent, but the results wher e not good as I wanted.
Best regards
A safer way and simpler way is to specify the displacements as formulas. Radial displacement would have the direction vector of (x,y,0). Mecway will substitute x and y with the coordinates of each node. That automatically generates the appropriate *TRANSFORM cards for CCX.
Here's an example of circumferential displacement done that way.
thank you very much
