Hi to everyone! I'm a structural engineer and I'm a CCX user from some years. I tried MecWay for generating .inp file to perform nonlinear analysis. I saw that Mecway doesn't write all the parameters:
First increment, step duration, minimum increment and maximum increment. Follow an example
*Static, SOLVER=SPOOLES
0.10000, 1.00000, 1e-05, 1.0
Other problems is that Is not possible to manage the maximum number of increments in the step:
*STEP,NLGEOM=YES,INC=100 (Written by Mecway)
For large plastic strain is important to register more than 100 increments
Other aspect is the application of *AMPLITUDE card to *CLOAD. Mecway builds ad *AMPLITUDE for every nodal load but is possible to apply the same *AMPLITUDE card defining only one *CLOAD for all nodal loads applied to a surface:
*Cload,OP=NEW, AMPLITUDE=AMP1
5,1, -0.56395427E-13
59,1, 24.000000
60,1, -0.50931698E-13
61,1, 24.000000
62,1, -0.52086157E-13
• Node number or node set label.
• Degree of freedom.
• Magnitude of the load
Other problem for me are the units. I prefer a unitless inp file. So one unit must be 1 mm. Mecway writes it in meters and al results are in Pa (Using CGX). Obviously I prefer MPa.
I have others advices: for example is important to compute the overall forces applied to the model before performing the analysis. It is important if one works on model with minimal supports and balanced loads.
I have other advices about how to build material models to solve in CCX....next time
Thanks for your answer. I looked at some video tutorial
about Mecway on youtube and I saw how to manage the inp file direct from the
pre-processor. Obviously is a good way but I'd like a pre-processor fully
integrated with CCX...obviously is my desire but I think that many CCX user
could desire this macros and others. About units I have a curvature on
structural steel and so I used always N/mm/kg/s for all the parameters. I know,
for example, that steel density on this set of units is uncomfortable: 7,85 x 10e-6
kg/mm3 instead 7850 kg/m3 but is only a practice aspect.
I bought a commercial license of Mecway this morning and I
hope step by step I will understand how to use it in a better manner. I used
Roshaz for some years and it was a very good project and some capabilities (all
quad mesh - loads summation before launch the solver, Gencoz force distribution
and so on) could be a developement for Mecway.
I must say that after 7/8 hours in Mw I appreciate the simpicity and the quick learning curve. For the rest I have to working manually on the inp file like first because Roshaz doesn't support latest CCX capabilities: for example considers contacts in a manner that is not longer supported by CCX (set of node VS set of elements).
I like that this communities is active and the project goes ahead.
Greetings
A note regarding Roshaz, John Horspool, owner and sole developer of Roshaz passed away in 2011.
R.I.P John ...so sadly this project can be regarded discontinued.
regards.
R.I.P.
