I am trying to model a precast concrete floor landing supported by a steel Channel beam section. For the temporary case the precast landing is just sitting on the top flange of the beam. but for the final load case there will be two welded studs tying them together.
1. How do I use the laminate material to model the reinforcement within the precast concrete landing
2. How do I model the contact between the precast landing unit and the PFC top flange so that this is like a compression only contact + friction.
I am trying to show the true deflection/twist of the PFC as a result of the orientation of the PFC.
what have i set wrong. lml file is attached
David
I've tried a bit of googling but I seem to get more linux based instructions which for use on a windows machine doesn't really work.
Cheers
I'm basically trying to move a very basic model in an x direction, then a y direction. I've started basic and tried to move it 2 separate directions in separate steps then i'll move on and see what i can do.
Hi Victor, thank you for the file
That's exactly what I did but when I import the file to Mecway and run it I only get movement in one direction? I've tried different analysis types and all sorts and can only get it moving in the initial direction.
Cheers
Ah ha, thank you. Got it moving in 2 directions now. A bit more editing and I think I should be able to get it moving in x 80mm then stay at x 80mm and then move in Y.
Thanks again
Cheers
