Distribute Floor Load/Pressure to Frame
Hello. I am trying to evaluate different non-square Stair frame configurations under a uniform floor load.
How do I transfer the pressure/ distributed loads from a plate to its subframe, without the plate adding stiffness to the overall frame? That is, I just need the vertical (normal) load distribution to each frame member.
I know the line pressures are not uniform along their frame lengths, but I don't know what the variations are. And as model sizes grow, it is quite tedious to first model a flat plate with normal supports along frame members axis, then transfer those reactions to the actual model (beam elements) as distinct nodal loads.
Springs? Plates w/ Node Releases (zero shear transfer in built-up section)?
Any thoughts?
~CWharPE
