It is my understanding that Victor worked for LISA. He left LISA and started Mecway. Mecway is essentially a fork of LISA. Mecway has some updates that LISA does not have.
Yes, that's right. Both businesses have an agreement to sell the product based on the same original code. A few of the additional features that Mecway has are:
- Both 32 and 64 bit. Much larger models can be solved with a 64 bit computer. - Fully units aware. There is no need to use a consistent unit system or remember what they should be. - DXF file import - New loads and constraints like frictionless support, compression-only support, elastic support and hydrostatic pressure. - Damping - Nonlinear static analysis for solid and truss elements. Only includes geometric nonlinearities such as stress stiffening and large rotations. - Loads and constraints can be applied directly to the CAD model by clicking surfaces - Sweep tool to generate shell and solid meshes extruded along curved paths
- DXF file import
- Damping
