Surface connection to single node
Just recently purchased the product an loving it.
I am trying to connect a single node to the surface of a bolt hole, I understand this can be done manually by making an element connect between the two nodes, one at a time but is there a quicker method to do this?
Seb
  • Sebastien, if you are using CCX as solver, there is a card called RIGID BODY that you can use for link a set of nodes to a master node, but is not implemented in the Mecway GUI yet, you must include using custom CCX data
