Calculix 2.11 MT
Hello fellow crunchers,
pls find a 64Bit Windows Version of ccx 2.11 via:
https://github.com/ddfem/ccx_mingw64
it is more or less untested, no bells, no whistles and no external libs.
Pls. give it a try an report back if there is any issue.
regards
  • Great! Have you compiled also CGX? Have read that both are needed.
  • edited October 2016
    Bad news kwip, I downloaded the executable (is only that?) and first run the usual test suite... lots of errors and ccx crash almost for any file. Then I try to solve a model from Mecway GUI and again... error! See the attachments.
    Guess that is a matter of touching something in my pc or maybe recompile again. By the way, have you tried to compile including the patchs to produce results in .med (able to read with Paraview)? That would be very very usefull and nobody did it for the moment in Windows.
  • Sorry I make a stupid mistake and download the 32bits version  :-) :-) :-) :-) :-)
    With the 64 bits works ok, the test suite gives me exactly the same results than with 2.10
    This is where the patchs for the Paraview results are:
    Regards!
