MECWAY'S COM ?
edited May 2014
No MECWAY's COM reference in the manual
Does it exist?
if it exists, Can you write a VB example?
  • It no longer exists sorry. It was too limited to be of much use. To generate a model programmatically, you can create an liml file.
    There is an example of a spreadsheet which generates pressure vessel components installed in the Samples folder (Mecway1\Samples\MeshGenerator.xls).
    To process results with your own software, you can use the table to automatically save the solution to a .csv file when it solves.
