Results range
Is it possible to define result range (min - max) in different way then "scrollbar" near results legend ?
I try to define acceptable stress range (eg. 0 - 235MPa VM), but it is not easy to do it by scroolbar....
  • Here are several ways:
    1. Sliders as you said.
    2. Right click the slider and choose Max/min and type in the values.
    3. Select some nodes, faces, or elements. Right click one and choose Fit contour plot max/min to selection. This only works for single value field variables, so if it's disabled, open the tree and select one of the components. Eg, it won't work for Stress but will for Stress XX.
  • Method "2" works perfect. Thx :)
