Option to keep results outside .liml file?
Hi Victor, is possible to add in the future some option to keep results outside liml file? I'm making backups/file sinchronization and I can configurate to skip some file extensions (.frd by example), but for liml I must open every one and remove results to make things faster.
  • Sounds like something for a command line option. I'll see about adding that for version 8.
  • edited August 2017
    Could be as an extra tool, but why not an option on the program to keep outside by default? I mean, Abaqus, and NX does in that way to don't inflate the models files.
    PD: I can answeer myself... doing an extra tool is easier, is just reading the lml and remove the result portion, but the other way is changing several parts of the program :-). But again, for bigger files can be more productive to read the results only when you want to postprocess and not to see the model or boundary conditions
