Multiple selection of faces in geometry view
Hi Victor, could it be possible to add multiple selection of faces on the geometry view? I meant, have the possibility of draw an rectangle or circle and then select all the faces bellow it. Now the only way is select one by one and for small faces can be distubing. Maybe adding also the menu option Select All and Invert Selection for geometry surfaces for having the same selection tools for geometry than for meshing. See the picture bellow to see a good case for multiple selection.
Also, in the geometry view, can be visualized the edges of the faces? And what about adding different colors for components??
Best Regards!
  • All good suggestions. Thanks. Not sure when though.
  • Great! I was able to select it all using the slice control, but is not very comfortable.
